i am rendering on max 2008 64bit with vray s1.5p1 with DR on 5 computers and getting vertically misaligned buckets on some renderings. It is happening on two different projects and it only started happening few weeks ago. I've rendered thousands of frames of both projects in the past with exactly the same setup without any problems. It is not that same node will render incorectly, but it is rather random thing.
Restarting rendering usually solves the problem, but restarting is not an option when rendering sequence of images. I usually wait to see if first image will render correctly but then sometime it starts ok and then after few frames it starts rendering wrong buckets and after that goes back to render ok.
Did anyone have similar problem?
Thanks
Thanks
