vrfb dragging exits max/viz
  • vrfb dragging exits max/viz
    Recently I'm experiencing frequent and serious 3ds viz 2008 crash during vrfb drag and drop or zooming and panning, anyone else? ... is it a known bug?
    In the beginning it happened (well, I noticed it) during render time but now I can simply render something at large res then move around the screen my vrfb window and Viz exits without any message.
    I'm running on Quad, 4 gb, quadro fx1500, vray sp1
    it happens with maxtreme and direct 3d as well
    any suggestion?
    thanx in advance
    upd 1: max frame buffer work as expected, no crash or whatever
    Alessandro
    There was a particular issue with the VFB that could cause a crash when the VFB window loses the focus; this should be corrected for newer builds.
      thanx vlado for your ultra fast answer but to me it doesn't seems related with focus, I mean not only with that.
      Just for test I re-opened my scene and click render, after a few buckets are gone without issues I had started to grab the VFB moving it fast around the screen to stress it; after a few seconds everything went away; no other apps running, no focus on anything else; it happens via backburner as well
      In the meantime I'm considering to switch back to max FB to avoid any risks forgetting about this issue.
      Alessandro
        I never had this one, but may it be related to video drivers?
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Not really; it's some obscure 3ds Max thing; the crash (at least the one I know of) actually occurs inside maxscrpt.dll... go figure...
            LMAO, talk about clean code...
            May it be due to the macro-recorder enabled?
            Or the fact max doesn't like the color red?
            Or tall buildings?
            Lele
            Disclaimer:
              Hm, it might be related to the macro recorder, I have to check.
                Well, I don't seem to have the issue under max 2008 64bit and VRay 1.5 sp1, under XP64bit SP2.
                NVidia 8800 GTS 640mb, latest release drivers, no maxtreme, Direct3d, macro-recorder enabled (there's no output whatsoever in it related to the vray vfb).
                Lele
                Disclaimer:
                  thanx guys for lookin' into
                  right now I can say that:
                  the past days the issue appears frequently
                  now it seems less frequent (but probably it's me and my focusing on that)
                  actually I'm not able to reproduce it in a consistent way, sometimes it happens sometimes it doesn't
                  I don't know how to check the macrorecorder thing or the maxscript.dll one, anyone who knows how to do it?
                  edit: definitely it's not anyway related with the scene: I just test with an ultra simple scene (array of teapot), everything default except GI ON, vrfb ON, show calc phase checked; start render, grab the vrfb to move it fast around the screen... after a few seconds everything is gone
                  Alessandro
                    Well, the macrorecorder is on if you see commands spit out in the tiny pink window on the bottom left of the max interface.
                    It's off by default, anyways.
                    As for the bug being related to the specific dll, you'd likely have to have debugging tools (as a standard error simply quits you out with too few infos given).
                    Could you post a test scene, with correct size and features used at the time of crash?
                    I really don't seem to be able to get it to happen here.
                    Lele
                    Disclaimer:
                      here it is
                      http://rapidshare.com/files/101771758/test.zip.html
                      as I said, simple array of teapot
                      I can also add that right now I tested it on a different PC, same issue
                      1. q6700 xp64 4gb quadro fx1500
                      2. dual xeon 3.2 xp 2 gb realizm 100
                      let me know
                      thanx in advance
                      Alessandro
                        It's not doing that here, no matter what i do.
                        Max redraws when the window goes on top, sure, so that is somewhat intensive, but it never crashed on me, while max was windowed or fullscreen.
                        I had winrar open as well, and the VFB was redrawing that too (which is odd).
                        Still, no issue here (config as of my previous post).
                        Lele
                        Disclaimer:
                          Lele, thanx for your time..
                          ...mmm, let me guess... it begins to appear as another great gift from autodesk related with the useful differences between max and viz?
                          I'm thinking that because it's the only common item (other than vray sp1, of course) on my 2 PC and it differs from yours
                          could you try stretching hard the vrfb window as well, to see what happens?
                          anyone running Viz 2008 would be so kind to test it?
                          Alessandro
                            Well, the file "d3dgfx.drv" which sits in the max root is version 10.0.0.86 here.
                            Check what version is yours so at least we can take that issue out...
                            I did try stretching, moving, zooming, maximising, and the lot. no issue.
                            Lele
                            Disclaimer:
                              I'm getting the same crashes inside Viz2008 when I either scale or move the vfb around the screen during the render or even after it's complete. It's a pretty hard crash with no error boxes (everything pretty much instantly closes and I lose the render
                              Just wanted to chime in and say I'm getting the same problem.
