Force a color
  • Force a color
    I'm using a physical camera/sky setup and the biggest problem I have to deal with is color tinting which is a result of the GI process but never the less the color of the sun and sky usually tints colors and materials yellow or orange. For instance if I have a light grey it will come out tan in color instead of grey, so how would one force Vray to override the tenting effect to produce the color desired?
    By the way I know this isn't physically correct and Vray is doing what it's supposed to, however it's hard to explain this to a client, regardless of how things work in the real world.
    White Balance
    Use v-ray's physcal camera white balance.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I've tried this and right now it's set to custom 255,255,255 but it has no effect. Perhapse I don't know how to use it properley.
        White Balance
        Basically you add the color you would like to remove into the RGB field.... I think
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          That seems to work, I had it backwards I thought you added the color you wanted.
            Camera
            Have you tried Lele's exposure script? I use it on almost every project.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              No what is it and where do I find it?
                lele
                http://www.chaosgroup.com/forums/vbu...highlight=lele
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  If you're looking for a particular surface to display an exact rgb value check this out... http://www.chaosgroup.com/forums/vbu...ad.php?t=36937
