Emergency - Vray Script Error
  • Emergency - Vray Script Error
    Hello friends !
    We wanted to get the REVIT Materials to VrayMaterials.
    For that reason, we changed some minor parameters - the script worked fine until we installed the new realease.
    Now we get all the time this error:
    I've uploaded the script here;
    http://www.bernhardrieder.com/ask/vrayutils.ms
    Would be great if someone knows the bug.
    Or maybe there is already a script that works with the scene converter and Revit.
    Thx a lot,
    bernhard
    rieder.bernhard@gmail.com
    I remember there was the same error in another place; I have to check how it was fixed. The reason was that something changed for MaxScript between 3ds Max versions...
      ok
      thx vlado, appreciate your hard work...
      bernhard
        I have also had this error recently and had to change all the materials by hand...
        If there is a fix we also appreciate your hard work vlado!
          So in the MaxScript, where is says
          Code:
          	if (r.texmap_diffuse) then (
          change it to
          Code:
          	if (r.texmap_diffuse!=undefined) then (
          and it will be fine.
            thanks very much.
              uuaaahh
              Hello !
              vlado, I am sorry, but I got another error:
              would be great if you can help ,
              bernhard
                Same thing, check the if-statement before the colored line and change it accordingly.
                  well..
                  hmm, ok, there is no if-statement for the reflection, in my script.
                  anyway, I could fix it.
                  thx vlado,
                  bernhard
                    grrr...
                    Hello,
                    I switched today to Max2008 and guess what.... the script doesn't work anymore...
                    here is the error....
                    What do I need to change ?
                    thx for help,
                    bernhard
                    ps: the script I am using is here:
                    http://www.bernhardrieder.com/blog/vrayutils.ms
                      uuahhh
                      sorry sorry folks, my fault, its' fixed, my script works, I just forgot to overwrite the existing one....
                        Has anyone had any luck with this script? I have been developing techniques to improve interoperability between Revit and 3dsMAX and if this script worked in the latest releases of 3dsMAX/Vray it would be really useful
