vray freeze with spline animation!!
  • vray freeze with spline animation!!
    Hello
    I try to animate some splines which is visible in render at frame 0 vray render well but after that frame vray freeze with all display is 99:99:99 at frame 99...
    With the netrender everything works fine.
    I am using vray 1.5
    thanks a lot for your help
    regards
    Mickael
    Are you using SP1?
      Hi vlado
      No this is the reason why I send you the info for my login and password...
      ps: sorry for my english
        I could be wrong but check if the splines are using adaptive interpolation - as the splines animate they could be changing vertex count and making vray freak out - especially if you're rendering with motion blur.
          I looked but the parameters has unchecked and I unchecked the optimize to see but I have the same result...
          thanks for your help Joconnell
          Does anyone can make a test with vray 1.50 sp1 :
          -simply create a spline
          -enable in renderer and in viewport
          -add a thickness
          -animate some point of the spline
          - Render using vray and see the result
          Regards
          Mickael Attia
          Ps : I am using vista 64 bits and 3sdmax 9 64 bits
            This is corrected for SP1, so you'll have to update to that.
              thanks a lot vlado
              but nobody answered me for the support access...
                Can you send me a private message with your email address so that I can check what happened with this? It is possible that they replied, but you didn't receive it.
