Vray Sky 'specify sun node' doesn't work....
  • Vray Sky 'specify sun node' doesn't work....
    Hello, if I set the vray sky map to manual I can't specify a sun node, as a result if I move the suns location, the manual vray sky doesn't change it's appearance to match the sun location. I want to make a slight adjustment to the sky's brightness relative to the sun, but still retain the sky's coded link to the sun's location to animate a sunset, with the appropriate sky color changes that occur as the sun moves.
    You should click the sun node button and then click on the sun light that you want linked to the sky texture.
      thanks Vlado, that worked. You might consider adding that in the help files in the future, as it is not explained well. Thanks again though....
