Invalid normal array
  • Invalid normal array
    Hello,
    I'm using max 2008 64bits (xp64) and vray 1.5 sp1...
    All rendernodes return : an Invalid normal array error occurred the program will terminated
    Any idea ???
    My Flickr
    Sounds like a mesh problem to be, probably some object in the scene is causing it.
      Thanks... I was thinking about something like that...
      I'm using CAO files... Something unclean
      Best regards...
      My Flickr
        Mesh problem for sure, try running a smoothing modifier on the offending geometry and see if that helps.
        Two heads are better than one ...
        ....but some head is better than none.....
          if you have loads of meshes you could try selecting half of them and then render, if okey invert selection and do the same again and again until you found the problem mesh.
          My Homepage : http://www.pixelstudio.nl
            It was a mesh problem ...
            A mesh from CAD software (Solidworks..)
            Best regards..
            My Flickr
