Another Map and DR problem
  • Another Map and DR problem
    Hello,
    I've just changed to Max 2008 and Vista 64.
    I was using Max9 with vista 64 before on another machine with 4 slave renderers.
    When using DR, no texture is found by all other slave renderers.
    Well, all my texture access use "\\PC\3dsmax..."
    I thought it was due to Vista that blocks everything but after some experiments with
    Backburner, I can say that there is no problem of texture access...
    In an animation, all the computers see the textures....
    So I don't understand, the problem only happens with DR for one image...
    What is it wrong ?
    Thank you
    Gael
    How do you start the DR spawner? As a service or manually?
      Yes, that was the problem, I have tryed it manually before going to bed and surprise !
      it was the cause, you're right...
      Everything works well now ...
      Thank you
      Gaƫl
