There's one vrayies and one normal ies turned on in this scene. They both use the same .ies file, but as you can see, the yellow one (vray) has a really sharp border around it. If i move the vray light further up from the illuminated survace, it will show as a really sharp circle, rather than a soft distributed light.
Something is wrong with my vrayIES
There's one vrayies and one normal ies turned on in this scene. They both use the same .ies file, but as you can see, the yellow one (vray) has a really sharp border around it. If i move the vray light further up from the illuminated survace, it will show as a really sharp circle, rather than a soft distributed light.Dusan Bosnjak
http://www.dusanbosnjak.com/Tags: None
Could this be caused by the cutoff value or the "use light shape" checkbox? Do these properties have the same value for both lights? Maybe one light has a higher power value?
Just throwing some suggestions at ya. Don't really know the actual reason
Edit: never mind, you're using a normal IES and VRayIES... doh...
It was the cutoff parameter. Changing it to 0 will result in a proper distribution. What's the cutoff for anyway? 0.001 creates these rough edges, 0.01 turns off the light completely.Dusan Bosnjak
I suppose it has to do with "cutting off" the shape of the IES from top to bottom like when they are placed in / to conform to a light fixture? Not really sure actually.
The cutoff parameter influence also depends on the IES file you're using. The value 0.01 doesn't always completely cuts off the light
I just hope that by setting it to 0.0 i am not doing harm in some other place. Like the render times...Dusan Bosnjak
Well, the higher the cutoff value (= less light distribution) the faster it renders. But I think that's normal. More light, so more to calculate . It doesn't make a whole lot of difference in render time though (the exact difference depends on the complexity of the IES data and the cutoff value). It does, however, make a whole lot of difference in the light distribution
