VrayLight Plane
  • VrayLight Plane
    Any idea why a VrayLight plane light might stop working? It renders in black regardless of how high I crank the settings.
    Do you have a texture on the light? Maybe you have the "Store with irradiance map" option on or the diffuse option turned off?
      Me too... (SP3)
      I'm having the same problem. I also noticed that changing a vraylight to a skylight portal and then back to non-skylight portal messes it up completely, and it can only be replaced for the intensity setting to work normally.
        Hm, it works fine for me...
          Solved it...
          I had Transp. cutoff set to 1.0 in Global Switches... changed it to 0 and voila - transparent VrayLights!
          Steve
