Material converter script
  • Material converter script
    I am trying to use the converter that installs on the quad-menu, "Scene Converter", but I receive an script error (see below).
    Any ideas?
    thank you
    Converting scene materials...
    Camera:3D to EXPORT
    Walls <Basic Wall : Generic - 1 mt : >
    Default Wall:Architectural
    -- Error occurred in convertFrom_Architectural(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 7787
    -- Frame:
    -- orig_mtl: Default Wall:Architectural
    -- l: undefined
    -- m: undefined
    -- r: vray Default Wall:VRayMtl
    -- called in createVRayMtl(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 10201
    -- Frame:
    -- fR_Glass: undefined
    -- fR_Advanced: undefined
    -- cls: Architectural
    -- sub_count: 0
    -- fR_Metal: undefined
    -- i: 0
    -- new_mtl: undefined
    -- called in replaceMtlNode(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 10791
    -- Frame:
    -- node: $Walls <Basic Wall : Generic - 1 mt : >
    -- m: undefined
    -- called in i loop; filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 10917
    -- Frame:
    -- i: 1
    -- called in replaceMtlNode(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 10921
    -- Frame:
    -- m: undefined
    -- Frame:
    -- i: 2
    -- Frame:
    -- node: $<root>
    -- m: undefined
    -- called in mtlsToVRay(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 11095
    -- Frame:
    -- called in convertToVRay(); filename: C:\Program Files\Autodesk\3ds Max 9\scripts\startup\vrayutils.ms; position: 11920
    -- Frame:
    -- called in anonymous codeblock
    -- Frame:
    -- res: true
    >> MAXScript MacroScript Error Exception: -- Type error: if-test requires BooleanClass, got: undefined <<
