No Render
  • No Render
    I am having an issue. My material library stops loading and when I hit render nothing happens. I am running MAX 2009 on a Windows XP64 workstation with V-Ray SP-2.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    No Render
    Here is what is happening.
    http://www.whitebirchstudios.com/pub...no_render.html
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I think if you show the little VRay messages window while rendering you'll find that it says in red "error: Could not obtain a license (10061)"
      Have you tried restarting your computer and also plug the wibi key into a different usb port?
      check in your browser localhost:30304 if the license really is running
      Kind Regards,
      Morne
      Kind Regards,
      Morne
        If everything seems correct, but you still have this issue, you can try to create an environment variable named "VRAY_CONNECT_TIMEOUT" without the quotes, and with a value "50000" again without the quotes.
          v-ray
          rebooting max solves it, but it'll happen again. I'll try the suggestions.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
