VrayFur Crash
  • VrayFur Crash
    I apply VrayFur to object. Everytime it crashes on "compiling geometry" The object was imported from elsewhere (Rhino) as both dwg (standard workflow) and iges.
    PS- Works fine on native Max sphere and plane.
    Thanks,
    T
    What is the memory usage when it crashes?
    Eric Boer
    Dev
      It instantaneously freezes. Ram doesn't budge, only using 1gb with 3 gb left. Vray Raycaster params at default. Win XP x86, Max 9 SP2, Vray SP2. Same scene VrayFur on plane = fine.
      Thanks for the help.
        Hmm, not sure hat it might be. First is the mesh in decent shape? Any double faces? Are the verts welded?
        Eric Boer
        Dev
          It is not a good idea to apply VRayFur on objects with large faces, you could try subdividing the base geometry a little bit and see if it helps.
