Distributed Rendering: slave machines portion renders dark
I finally got DR to work properly. Now the portionof the render that is done by my slave machine is comming out much darker than the portion done by my Client/Main machine.
tell us a bit more about your setup. Are you using LWF? are you precaching irradience maps/light cache? If so, did you make sure that the lightcache is on the network where both machines can read it? If you are using LWF did you make sure all the plugins such as color correct are installed on both systems...
