Hello,
I just installed Max Design 2009 64bits on my workstation and Max Design 32bits on my renderslave. I of course installed the corresponding version of Vray (SP2) on each machine.
When I start a rendering, the slave machine is found and the max file is transfered correctly (the Vray log shows "Server ip.address: Scene loaded : starting render"), but a few seconds later, I get the message "Server ip.address: Render completed" in the log, but the rendering is very far from being done.
Then the slave machine does not respond until the rendering is done.
For info, I've been able to setup DR for max 7, 8 and 9 (I never had the chance/time to install my version of max 2008...) without a problem. Everything was working fine with these versions and the same computers (win XP64 on workstation and XP32 on the slave).
Oh, and I did run a rendering job through Backburner...
Has anyone got any clue of what I might have done wrong during the setup?
Thanks a lot!!
Thanks a lot!!
