PFlow / VRay Displ.
  • PFlow / VRay Displ.
    Hi all,
    i know i've asked it already while ago. but i still have the problem that i can't use Vray displacement with PFlow.
    its really a pity. the standard mat-based displacement is a pain. and i need displ...
    i've try'd it with mesher but no luck.
    any ideas?
    best regards
    Jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    i'm just curious, what are you trying to make?
      i need particles, with Vray-displacement on each. i'am using an instanced object with vray displ. mod. but pf want render it.
      Jonas
      www.jonas-balzer.de
      www.shack.de
        You could try to use Mesher and then apply the displacement modifier on that.
          hi vlado,
          i already try'd that with no succes.
          Jonas
          www.jonas-balzer.de
          www.shack.de
            Hm, really, can you send me the scene for this to vlado@chaosgroup.com to investigate?
              sure, i prepare it. thanks.
              Jonas
              www.jonas-balzer.de
              www.shack.de
                Heya Jonas - if there's nothing born within the scene could you bake the motion to nulls and parent the objects to it? I've a few tools to do that for dealing with heavy instancing - they don't handle particles being born admittedly but if that isn't an issue it might sort you out.
                  ey mate. i hoped that you would answer.
                  unfortunately i have around 500 particles wich are born in a sequence of 200 frames.
                  but maybe i can restructure it, that they are born already and hided somewhere.
                  i'll look into it. thanks man
                  best regards
                  Jonas
                  Jonas
                  www.jonas-balzer.de
                  www.shack.de
                    I probably won't be getting around to it soon but it's something I have to handle eventually using visibility keys or similar - I'll give you a shout once it's behaving
                      i'll looking forward hearing it.
                      thanks man.
                      Jonas
                      www.jonas-balzer.de
                      www.shack.de
