Irradience map filename error
  • Irradience map filename error
    chris one of the 3d gurus here just found that in 1.50 SP1 (max200 that if the irradience map file has a 4 digit number (eg File1234)) at the end of the filename they get deleted from the name and then the animation cant find the ir map
    ie
    ir file - TESTfile0000.vrmap
    in max the filename after broswing to the ir map is called
    TESTfile.vrmap
    it works if its less than four digits
    if its more than 4 digits it cuts the number down to 2 digits
    eg
    testfile123456.vrmap
    becomes
    testfile12.vrmap
    havent tried sp2 as we are mid job
    cheers
    Yep, this is a bug that is fixed in sp2. I think you can avoid it if you type the file name directly in the edit box, instead of using the browse button.
      thanks
      cool
      cant wait to try animated proxies
