Slow Material Editor
  • #31
    !!!Mathsurf 2.0!!!
    Found that this plugin slowing Material Editor. In small scenes ME works fine, but when adding more objects - 4-6 seconds for each slot appearing.
    I removed it and fast ME came back!
    Hope it helps somebody!
    Z-Dimension WIP 1 WIP 2 WIP 3 WIP 4
    • #32
      Thats whats causing it, looks like i have to get rid of mathsurf...thanks for the tip.
      www.short-cuts.de
      • #33
        vrlsevice start error
        I've had this problem twice in 2 days now.
        Max has been running all day..then all of a sudden, ME won't open and hitting f10 for render settings takes forever....so bad I have to exit max.
        I check the localhost:30304 and it is in >>deny<< mode with no licenses showing. I should have Vray and VrayRT licenses showing. I terminate the vrlservice from the task bar, and when I try to launch it again I get this error:
        program needs WIBU-BOX with ######:#######
        vrlservice.exe start error
        (I ### out the numbers for the dongle as I'm not sure if that is a secure code or something)
        Anyway I have to reboot the machine to get the service working again. This only started happening a couple of days ago when I upgraded the dongle for the vrayRT.
        Simon
        I need a new signature
        Max2017.1 | Vray 3.70.01| win11
        ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
        • #34
          It is not very likely that this is problem of the license server itself; you can try to move the dongle to a different USB port of the same machine, or to another machine in the network, if possible. If you still have issues, please email us to vray@chaosgroup.com as it might be that the dongle must be replaced.
          • #35
            Vlado,
            I will monitor the situation and do as you suggest if it continues.
            I'm not sure if this is related but when it is working and I getstatus from the localhost:30304 I see my Vray license and VrayRT license but the I get these 3 lines just before the dongle info, is this correct?
            Default access: DENY
            Explicit allow
            Explicit deny
            thanks
            Simon
            • #36
              This is correct, yes - these are the normal values.
