VrayFur problems
  • VrayFur problems
    Hello, i'm working in a animation with vrayfur. It seems the best fur for vray.
    I'm having some problems with it, the most important is the density seems to be different when i put some modifier ti source object. The O letter is the same mesh in both cases.
    I have vrayfur distribution per aren in both cases.
    I need the same density in both letters. Is there any solution for this?
    www.gaell.com
    Well, the problem seems to be only when you have flex modifier and scale the object fron 0 to 100%
    www.gaell.com
      You can use the "Reference frame" parameter to specify the frame in the animation that will be used to calculate the fur density.
        Yes, i thought like you but the reference frame parameter seems not work here. I have 1.5 SP2.
        www.gaell.com
          Can you send me that simple scene to vlado@chaosgroup.com to check it out? Does it work if you use the PointCache modifier to bake the animation?
