Animation (prepass) not saving irradiance map
  • Animation (prepass) not saving irradiance map
    Hi Guys,
    We are using the irradiance map for animation and vray calculates the GI then when it goes to save the irmap vray spits out an exception.
    Now im just trying to save the maps to the local drive.
    Max 2009 x 64 vray 1.5 rc2
    Any ideas would be appriciated
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
    What location are you saving the file to?
      Just to the Root of C:
      Chris Jackson
      Shiftmedia
        vlado after a bit more investigation it seems to be related to image size and size of IRmap.
        I have been trying to calculate the GI at 1280x720px @ -3,-2 but that gives an error. If I reduce the resolution to 720x405 @ -3,-2 i dont get the error. But at 720x405 If I use -3,-1 it gives me the error.
        Very frustrating.
        Chris Jackson
        Shiftmedia
          sounds like a typical memory issue to me.
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            here is the error I get. This error appears when I use the materials in the scene and also a mid-grey override material
            Chris Jackson
            Shiftmedia
              Hi Morbid,
              The file uses 5gb to render and I have 8gb on XP64
              Chris Jackson
              Shiftmedia
                Originally posted by jacksc02 View Post
                Hi Morbid,
                thats cutting it pretty close. Let me get it right...your iramp file takes 5gb?? thats sounds really heavy to me. Perhaps simplifying your settings could help?
                Dmitry Vinnik
                ShowReel:
                  no no the whole scene takes 5gb to render
                  Chris Jackson
                  Shiftmedia
                    theoretically, if you render with irradience map per frame (single frame) and prepass of -1/-1 you can get a pretty flicker free result too. And you dont need to save that. So give it a shot.
                    Dmitry Vinnik
                    ShowReel:
                      If the irradiance map becomes larger then 2 GB, I can see where this would be a problem to save it to disk... I will check the scene though.
                        the irradiance map is not 2gb!
                        its only about 550kb per frame
                        Chris Jackson
                        Shiftmedia
                          vlado, did you have any luck with my file?
                          Chris Jackson
                          Shiftmedia
                            Nope, I don't have enough RAM to render it - my machine has only 4 GB physical RAM and it chokes on it; I have to check if any of the other machines here can handle it.
                            • #15
                              thanks for the update vlado.
                              If you cant look at it dont worry. I managed to render it single frame with no problems. I was just hoping to use the irradiance for animation option.
                              Chris Jackson
                              Shiftmedia
