Dirt doesn't work with dof
  • Dirt doesn't work with dof
    As continuing my material tests, I found that dirt is not working with dof.
    Can someone confirm or tell workaround?
    Dirt
    Dirt + Dof
    -LarsSon
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
    If you're using QMC for your AA, it may have something to do with the amount of samples. Someone presented a similar thing a while ago. Essentially, the DOF is demanding too many of the samples and thus making the dirt very low quality/barely visible, so you need to feed it more samples - increase the Max. Check if Adaptive Subdivision gives a different result to confirm this.
      Aah, I understand. Thanks for that idea.
      I'm using adaptive subdivision sampler.
      I'll try to max up samples next, lets see how it goes.
      -LarsSon
      Lasse Kilpia
      VFX Artist
        You could try to use more samples for VRayDirt and see if it fixes it.
          Man, that's a nice material!
          Would you share your settings?
            Well nothing much to share.
            There's Vray blend material mixing metal material and slightly rusty metal.
            Then there's rusty/dirty metal material with high bump.
            These materials are mixed using dirt.
            In this newest version all above is mixed with totally clean material using edgetex. That's how I get clean and shiny edges and corners.
            All materials have bump map mixed ueing bitmap and edgetex to get round corners.
            Not totally happy yet, but getting there.
            I can send material later, but that will be missing all Dosch textures.
            Lasse Kilpia
            VFX Artist
              mats
              These look really cool! I'd also love to take a peek at the material setup. Are you still able to share/show?
