Hi all
I have motion blur enabled on my VRPhysCam with 8 samples.
Bushes have VRay materials applied. Pure geometry, no opacity.
I render my scene with VRay and I get this:
scene.tga
As you can see the grass is messing up around my trees.
Now if I render again with VRay excluding the grass, then render the grass only with scanline and comp it into my scene, I get the excact same result!
grass.tga
But if you look at the grass only version, all seems fine!
I tried to exclude the bushes from motionblur by selecting VRay prop and deselecting "default mblur" and set samples to min which is 1. Not sure if that helps as it seems to get same result
Please Help this is rather urgent!
Running Max 2009 64bit, VRay 1.5SP2, Vista 64bit, 8GB Ram
scene.tga
grass.tga
