DR with Max 2009
  • DR with Max 2009
    Hello!
    There a lot of threads about DR with Max 2009 and Vray. Does it work or not?
    I´m using winxp64, max2009 and vray sp2. Backburner works fine.
    When i open the vrayspawner at the slave-machine the vraydummy starts and goes down into the task-bar.
    When i start the rendering - vraylog says connectet to host (name of the slave) with ip.
    - everything seems fine but not more buckets and after 2 minutes it says
    Warning: renderhost ...(ip) is not responding.
    Thanks for your help.
    Works fine here with 2009..
    What is happening in the task manager of the slave machine??
    Alain Blanchette
    www.pixistudio.com
      do you have firewall enabled on master/slave machine(s) ?
      3LP Team
        same problem
        same problem with 3ds max 2009. Any help here would be appreciated. Everything was working fine with Viz 2008, and now 'render host not responding' with 3ds max 2009. Here's our setup:
        Installed fresh 3ds max design 2009 and Vray 1.5 SP2 on render machine and nodes.
        Start vray spawner on render node and get the minimized vraydummy file in the taskbar (cool looks like it's going to work smoother than viz did for us
        Start the render from the render computer
        the vray messages window says render host xxxxxxx added
        no extra buckets show up in the rendering window
        then the vray messages windows says 'render host unknown xxxxxxx is not responding.
        then this cycles over and over about every 5 minutes.
        See the attached image for details. Running Windows XP SP3 32bit on every machine.
        We're running on 5 vray licenses and we've got a 20 computer render farm we're looking to get set up as soon as possible. Our production is slowing due to this problem and any help is much appreciated
        M-
        PS no firewalls or switch problems. Seeing as how DR worked fine yesterday with all of our Viz2008 setups, I'm thinking this is not a networking problem.
        PS2 - about the task manage on the slave machine - when the render is sent to the slave machine, there is about a 25% processor spike, with no change in RAM allocation, then it dies down and nothing, until the main render machine tries to send it again....then another spike....repeat.
          ok, got it worked out, I just needed to updated the backburner to version 2008.1
          For those with the same exact problem as I, here's what I did.
          Control Panel > add remove programs > Un-install backburner.
          Without un-installing 3ds max design 2009, run the installer again and it will just replace with the updated backburner.
          Ahhhhh, much better now
            Im confused...reinstalling the 2008.1 backburner sorts out the "render host not responding" problem that occurs randomly ??
            Regards
            Steve
            My Portfolio
              not exactly, I was suggesting that solution if you're having trouble connecting to the other hosts 'at all'. As for the random dropouts, I'm not sure what's up there. I haven't run across that problem yet = fingers crossed...
