Noisy Images with Realworld Mapping and Vray SP2
  • Noisy Images with Realworld Mapping and Vray SP2
    We noticed that as soon as we moved to Vray SP2 Realworld Mapping now renders with considerably more noise than previously, as if it is being rendered overly sharpened.
    Admittedly previously realworld mapping, or any mapping for that matter, was occasionally too blurry in the distance, but the change in SP2 is very marked and can cause some headaches in animations, swimming textures etc. The effect is more pronounced on detailed texture maps.
    I was hoping this may have come up before, but I can find no mention in any of the forums, hence starting the thread, I just hope this has been noticed by other artists, or whether Chaos can confirm if the rendering of Realworld mapping has changed in SP2?
    This is visible on all of our machines, including the renderfarm, completely consistently.
    Has anybody noticed this, or better still aware of a better fix than just blurring the textures excessively?
    as far as I understand the mapping has nothing to do with VRay, but is controlled by MAX. you can however in your bitmap settings on mat diffuse play with the filter, pyramid, summed or none. See if it makes a difference
    Kind Regards,
    Morne
      Thanks for the reply.
      However that doesn't necessarily explain why it changed in Vray SP2 though?
      It was immediately noticeable, as any project we had previously rendered in SP1 and earlier without issues, changed as soon as we installed SP2, but only the objects using Realworld mapping.
        maybe some kind of change in the VRayMat properties, like reflect and refract?
        Send Vlado a mail and ask for some clarity...
        Kind Regards,
        Morne
          Nothing has changed in V-Ray in this regard specifically. However if you have a scene that does not work as expected, please send it to vray@chaosgroup.com or to me directly at vlado@chaosgroup.com
            Hi Vlado,
            I have emailed you some max files as suggested, although it is apparent in any file tbh.
            For everyone else these 2 images demonstrate the issue, note it becomes apparent at oblique camera angles and using detailed maps, unfortunately this covers most architectural renders
            All I have changed is Vray SP1 to SP2 for the purpose of this test, and there is a marked difference?
              Have you tried it with scanline?
              Eric Boer
              Dev
                Just checked and as I suspected scanline looks as it always did, SP1 or SP2, which is to be expected as Vray shouldn't have any effect on Scanline renders.
                Of course I had to convert the materials from Vray materials to check, which did prompt me to try using standard materials instead of Vray materials in SP2, however this rendered the same as the Vray materials in SP2, so it would suggest it's not a Vray material issue.
                BTW These were rendered in Max 2008 64bit
                  We are using Realworld mapping very offen too, because most of our modeling is done with splines and RWuvs save a lot of time.
                  I hope this problem is of a simple kind, continue reading this thead.
                    You're not alone Trev.
                    We've been noticing similar issues when using bump maps that are real world mapped.
                    Has no one else noticed this?
                    Set V-Ray class properties en masse with the VMC script
                    Follow me for script updates: @ollyspolys
                      As far as I can see from the images, the problem is in the texture filtering, not in the texture mapping as such...
                        Was this changed in SP2 then? as the only difference between the 2 renders is SP1 and SP2
                          No idea; I have to check the source code version history.
                            So this is now corrected for newer builds and for SP3.
                            • #15
                              Thanks Vlado
