Lighting error
  • Lighting error
    Hi Guys,
    Seem to be having some problems with the light/shadows in a small area of an aircraft cabin.
    I have the light subd's up to about 60, so that shouldnt be the problem.
    Also, all lights shadow bias is set to: 0.0
    Global sudivs multi: 1.0
    Preset: Medium
    Irr map Hsph subdivs: 60
    Irr map Interp samples: 50
    Lightcache Subdvis: 1200
    Sample Size: 0.02
    I didnt think the preset needed to be any higher than medium as there were no other errors on the rendered image.
    That pink/purple mesh is positioned so that no light should escape from that section, yet it still does.
    Any ideas ?
    Regards
    Steve
    My Portfolio
    try render it with detail enhancemen ON and see if thats helps.
    also try that:
    Hsph subdivs: 120
    Irr map Interp samples: 60
    and for lights: store with IR map: unchecked
    if u left it checked, at least put subd's to 200 and see if thats helps., u can try send me the that scene, ill try to help ...
    Andrian
    _____________________________________
    www.fekta.eu
    Portfolio
    CG Talk
      Thanks for the reply...It turned out it was because the mesh for that particular object was only 1 sided...vray obviously doesnt like 1 sided meshes..
      Cheers
      Regards
      Steve
      My Portfolio
