Vray Sky Frames Per Second fps
  • Vray Sky Frames Per Second fps
    I am having a strange problem occur when I am rendering my scene. I have a scene where for different segments I would like to render different fps-in order to time-remap certain segments later in post etc. Same camera. At 24 fps with a vray sky linked manually to the vray sun in the environment slot the scene renders beautifully. However, any other fps results in the scene rendering very dark. Any ideas here? I've recreated the sky and merged into a new scene. I've never encountered this before and have rendered different fps in the past without fail. Please help Thank you
    Solved!
    I figured this one out myself and hope that any one confronted with the same problem stumbles upon this post. Simply put, when you change the frame rate by a given multiple the film speed of the vray camera is directly related. If you were rendering 24 fps at 100 film speed and switch to 96 fps then your film speed will be 400.
