pflow problem
  • pflow problem
    im getting unhandle exception error rendering a simple animation of 20particles. The particles are shape instanced sphere with a noise modifier. The problem only appears when render the animation.
    How can i fix this problem.
    www.gaell.com
    The first frame always render perfect, the error pop up starting the second frame.
    Error message: Unhandled eception: preparing instances.
    3dmax 2009 SP1 creativity extension + Vray 1.5 SP2
    www.gaell.com
      I think the problem is related to the noise modifier, If i disable it the render goes ok.
      But i need the noise animation. What can i do?
      www.gaell.com
        Which object is the Noise modifier applied on?
          Maybe the error message is displaced due to an overflow of your memory limitation of 1.7GB per application, if working on a x86 (32-bit) OS.
          --> http://www.tobyatwork.de
          --> http://www.scriptspot.com/blog/toby
