V-Ray Matte Object - Noisy/unfiltered background
  • V-Ray Matte Object - Noisy/unfiltered background
    I'm working on a scene where I'm dropping in some objects over a photograph by reconstructing the objects in it, camera matching the perspective & setting them to Matte Objects in the V-Ray properties.
    This all works as expected - apart from an odd issue that the environment I have behind the objects doesn't render 'cleanly', it looks noisy/unfiltered.
    Here's an example:
    Background image
    Alpha of matte object
    Render
    Close up of problem area
    It's not hugely important as I'm going to comp everything in photoshop & won't actually use the raw renders, but the image is very large & it would be nice if my test renders were closer to the finished article.
    Any ideas?
    Cheers.
    AJ
    MDI Digital
    moonjam
    Which V-Ray version are you using? I remember there was some kind of issue there and that it was fixed, but I have to check when this happened.
      Ah - I see we're still running 1.50 SP1...
      I'll update & see if that fixes it.
      Cheers Vlado.
      MDI Digital
      moonjam
        Yep - that's fixed it.
        Thank you!
        MDI Digital
        moonjam
