Irr map causing light error
  • Irr map causing light error
    Hi there,
    Got a problem with an animation im working on.
    I have attached an image. The left side is where the lightcache and irr map are loaded from pre-calc and then rendered...causing the light problem. The right side is where ive loaded the lightcache from file and calculated the irr map on the fly (so no pre-calc for the irr map).
    There are only 2 spots on the render that this is happening. Any ideas what this could be ?
    The irr map was calculated at medium-animation both times. The pre-calc irr map was calculated on 3 different machines and then merged.
    Regards
    Steve
    My Portfolio
    What do you have at the windows? Do you have a VRaySun in your scene?
      I have a vray plane light at the windows...store irradiance map on and invisible. Also have a sun in the scene...set to invisible also.
      Regards
      Steve
      My Portfolio
        Such problems typically happen when a GI ray hits something bright in the scene; it could be due to GI caustics (reflective or refractive) or because there is some bright and small object in the scene (or maybe gap between objects through which a much brigher object is visible). The chance for getting such issues increases as you take more samples, so that's why it may happen with a fly-through map, but not with a single frame map.
          Ok Cheers. I'll check the scene for bright areas and gaps in the mesh...
          Regards
          Steve
          My Portfolio
            Do you think I will have to recalc the entire 420 frames again, or is there a way to just replace the dodgy areas ?
            Regards
            Steve
            My Portfolio
