Resubmitting render with DR to quickly causing crash
  • Resubmitting render with DR to quickly causing crash
    I'm not sure if this is specifically a vray problem, but when I re-submit a render with DR enabled too quickly, max crashes to the error report dialog.
    I assume the problem is related to the reload-nodes maxscript that restarts my spawner services. Perhaps sending a DR render when the spawner services are in the process of restarting causes the host machine to crash.
    Is this a known problem?
    Patrick Macdonald
    Lighting TD : http://reformstudios.com Developer of "Mission Control", the spreadsheet editor for 3ds Max http://reformstudios.com/mission-control-for-3ds-max/
    The spawners cannot cause the main machine to crash ideally; does it happen with any scene, or just with a particular one?
      I've only just noticed it so it may well be just this scene. I'll do some tests.
      Patrick Macdonald
