Scripted Vray Materials
  • Scripted Vray Materials
    Hi there,
    I´m really new (inexperienced) to scripting.
    I followed an example in the maxscript documentation
    to extend a Standard material with a new rollout,
    that controls some basic parameters of the actual material.
    With a standard material it works fine.
    But when I replace the standard material with a VrayMtl, I get an error.
    plugin material s_test
    name: "s mat test"
    classID:#(0x2dbc484f, 0xc76a672)
    extends:VRayMtl
    replaceUI:false
    This is how I expected it to work, but I get the following error.
    -- Error occurred in anonymous codeblock; filename: ; position: 7
    -- Runtime error: Plugin redefinition: cannot change extends class. VRayMtl
    Is it possible at all to do it that way ?
    What am I doing wrong ?
    Thank You,
    sam
    Yes, it is possible to base scripted materials on VRayMtl (all the Egz materials work this way). I am not sure about the exact reason for the error though - perhaps you need to use a different ClassID?
      Great, it works now.
      I needed a new classID and name when changing
      the extends:Standard to extends:VrayMtl
      Thank You,
      regards,
      sam
