Vray DR Problem
  • Vray DR Problem
    I hope somebody can help me here...
    My configuration: 2 computers for Rendering
    workstation: at the moment win xp prof 32 bit+3dsmax 2009 service pack1+Vray 1.5SP2
    slave: now windows xp prof. 64 bit with 3dsmax 2009 service pack 1 32+64 bit with both vray versions( 32,64bit) for DR
    When i was on both with win xp prof everything worked fine---but now i had to reinstall the slave and i thought why not win xp 64bit--because the slave has 4 GB RAM.
    pinging between the computers is no problem...everything quite normal.
    Vray Spawner also works---there are no crashes.
    But when rendering in DR mode the slave can t render.
    Vray log says: server xxx scene loaded, starting render
    ??? server xxx, render completed ???
    the in green: wwarning: render host xxx is not responding----
    Has anybody some advices?
    http://www.sehorst.com
    Is the windows firewall enabled?
    Derik Bibb
    Architectural Visualizer
    TANGRAM 3DS
    International 3D & Design Solutions
      re
      problem solved.
        re
        windows firewall was off....but it s solved now thank you
          Excellent! what was the problem?
          Derik Bibb
          TANGRAM 3DS
            re
            with windos xp prof 32 bit i just installed the DR/networkrendering installation without telling him the IP where the vray licence is running..everything worked fine...now i just had to tell him the IP of the workstation where the licence is running...that was all-
              DOH ..
              trying to problem solve human error is the hardest problem to solve..
              Natty
              http://www.rendertime.co.uk
                We often have this problem too. Have noticed that we only have the problem with large files (200+ Mb). Small files is usually no problem. Sometime it helps to "wake-up" the renderfarm by sending a small file to rendering before sending the large file to.
                /Chris
                  DR Large Max Files
                  Has anyone else experienced problems Distribute Rendering large Max files, say +100mb? I usually don't have a problem with small files but everytime I have a large Max file none of the Render Slaves pick the job up. Any suggestions/tips/tricks??
                  Thanks in advance,
                    Yes, I have the same issue. Files that are typically over 100MB will not DR. No solution found on this end, perhaps XREF's.
