pre-render script vs. Vray
  • pre-render script vs. Vray
    I have a pre-renderscript which just set another save path for IRRmap
    renderers.production.adv_irradmap_autoSaveFileName = "X:\\maxtest\\muh.vrmp" as string
    in vray RC3 I get error
    Saving irradiance map to file "¼╞╓§8▌X♫st\test.vrmap
    is there a work around Vlado ?
    I know RC3 is very out of date but I must run it beside all the other RC and SP release to be "compartible" to my clients
    a.
    __________________________________
    - moste powerfull Render farm in world -
    RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
    just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
    Is it possible to UNC the path rather than using a drive letter?
    If I remember correctly you need to format it like this:
    \\\servername\\folder\\file.vrmap
    Not sure if that will help you.
      Hello,
      Some help for your scripting.
      at first, when you build a string with " .. " there is no need to parse it to string.
      Code:
      as string
      If you using slashes => \ you have to escape everyone, so unc path will be
      "\\\\server\\folder\\file.vrmap"
      when using backslashes => / you dont hav to escape, so unc path will be
      "//server/folder/file.vrmap"
      Both give same result.
