vrimg help!!!
  • vrimg help!!!
    I need to render a high res image that is crashing my computer--I am trying to use the vrimg file format--are the render elements such as zdepth stored in this file? cant seem to find them!
    When you open the vrimg file do you just use the normal image viewer in max or is there a vray image viewer?
    Thanks for you help in advance
    you need: vrimg2exr
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      still having problems
      thanks tricky for the quick post--I am using vrimg2exr now but am still having trouble getting my zdepth file--I am posting some images of my command lines--thanks again for your help
        what version of vray you use? - I am not sure but I remember a bug in one of the older releases Z-layer vs vrimg
        __________________________________
        - moste powerfull Render farm in world -
        RebusFarm --> 1450 nodes ! --> 2.900 CPU !! --> 20.000 cores !!!
        just 2,9 to 1.2 cent per GHZ hour --> www.rebusfarm.net
          vrimg Z Depth still not working
          I am using version 1.5 rc3--in the vrimg2exr I can save out all channels I use except for the ZDepth
            must be the bug then - RC3 is older then my mom - get latest and it will work for sure
              definitely get the latest version from the downloads section. Also, you can render to exr using the VRFB. Just change the extension. Check out the help documents for more details.
