Bump map BUG
  • Bump map BUG
    Hello guys,
    We ve got a strange bump map issue here. Havent tried it with SP3 yet, but were getting it with SP2 on max 9, max 2008 and max 2009.
    Here is the description:
    When we create a scene using meter units we encounter quite a troublesome bug on bump mapped materials in the areas where there r direct shadows.
    You can easily see it on the picture below. It doesnt matter if we use sun or direct light or if we tweak bump map filtering and blur etc...the bug persists
    On the other hand, when we use mm units system, the bug is not present.
    however...because of this bug, we cannot creat large scenes..
    Please have a look at the picture below:
    can anyone help please???
    Thanks a lot
    Best regards
    Martin
    http://www.pixelbox.cz
    What is your shadow bias set to in the light settings?
      ha...vlado )))))
      you solved it we ve had it to 0.2m
      thanks a lot!!! youre the man!
      best regards
      Martin
        it is only strange that without bump map it works correctly even with a shadow bias se this high
        any idea why?
        Martin
          It is because the shadow bias causes the shadowed point to be moved along the surface normal; the bump map changes that normal, so the shadows are sampled at very different points depending on the bump.
            right ...great to know that Vlado thank you !
            Martin
              I like depth map shadow
              Dmitry Vinnik
              Silhouette Images Inc.
              ShowReel:
