displacement problems
  • displacement problems
    I'm having some real major issues with displacement - not just with SP3, it happened with SP2 as well.
    Basically I'm applying displacement to a large area of carpet. Maybe a bit ambitious to start with (?), and I'm leaving all the settings as default. Both computers I'm rendering on have 16gb of ram.
    Test renders at 1k go without a hitch.
    So I then up the resolution to 3k.
    I set the dynamic memory limit to 4000 and things start off ok. I get several rounds of 'unloading geometry' during lightcache with my ram usage at 6.85gb. Then about three quarters of the way through the IR map calc, with the ram usage still at 6.85gb I get 'unloading geometry' and then it crashes.
    So I then admit defeat and delete all the displacement from all the objects in the scene and also remove all traces of it from the materials.
    When I do another render I still get 'unloading geometry' as if the displacement is still there. It also ends up crashing at the same place again.
    I've even tried merging the old file into a new one to see if it will leave the 'phantom' displacement behind, but it doesn't.
    So I uncheck displacement in the Vray global switches menu, in hope of switching off all traces of displacement. But I get exacly the same thing happening - unloading geometry and crash.
    Is there a bug that doesn't allow you to remove displacement once a scene has crashed?
    .:www.mcphersonyachtdesign.com:.
    it could be that you need to switch back to static geometry...
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks morbid, will give that a try.
        Not sure if this is the problem, but if you have 16 gb of ram you can set the dynamic limit alot higher than 4000... try 12000, then vray shouldnt have to load/unload geometry all the time.
        Also, if youre using 3d displacement, try 2d instead. It uses alot less memory.
        /k
          /k
          this isnt correct, vray does not allow to set the dynamic limit to more then 3000.
          Dmitry Vinnik
          ShowReel:
            untrue, Dmitry.
            I myself set it to 16gb to avoid another issue happening with very dense geometry as base, and it always worked.
            64bit though.
            You can check the wiki of where you are now for infos
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              when i press any value over 3000 in the dynamic memory limit it reverts to 3000. What can you say about that?
              Dmitry Vinnik
              ShowReel:
                Nuno de Castro
                www.ene-digital.com
                nuno@ene-digital.com
                00351 917593145
                  Originally posted by ene.xis View Post
                  I am not blind...Yet I cannot set the limit over 3 gb.
                  Dmitry Vinnik
                  ShowReel:
                    don t take me wrong, i must have misunderstood ur previous post, nonetheless i am pretty sure the ram usage goes above 3000, maybe i can slip in some image....again
                    Nuno de Castro
                    www.ene-digital.com
                    00351 917593145
                      Well, as ene pointed out, it does go above 3gb.
                      The 32bit does not, of course.
                      The only thing i can think of is that you're using that one, but then, i know you know what you're doing, so it's unlikely
                      What version (exact build number) does that?
                      Lele
                      Disclaimer:
                        Man, that was an evil way of putting it. Now what's he gonna say on the off chance he didn't think of that?
                          LMAO XD
                          I have to say i didn't realise it was a lose-lose situation i was putting him into :P
                          Let's say i could also think about overwork, stress, morning blues that could have him getting that one wrong.
                          Or, it goes without saying, me never realising it's actually as Dmitry says it is.
                          And ene is photoshopping screenshots like mad, ofc :P
                          Lele
                          Disclaimer:
                            and finds silly numbers for the dyn mem limit too!
                            edit:
                            nonetheles i'll test it out for the sake of (non)scientific experiment later and report it...
                            i ll photoshop the results that is, of course!
                            Nuno de Castro
                            www.ene-digital.com
                            00351 917593145
                              Originally posted by Depeche Mode
                              Words like violence
                              Break the silence
                              Come crashing in
                              Into my little world
                              Painful to me
                              Pierce right through me
                              Cant you understand
                              Oh my little girl
                              All I ever wanted
                              All I ever needed
                              Is here in my arms
                              Words are very unnecessary
                              They can only do harm
                              Vows are spoken
                              To be broken
                              Feelings are intense
                              Words are trivial
                              Pleasures remain
                              So does the pain
                              Words are meaningless
                              And forgettable
                              All I ever wanted
                              All I ever needed
                              Is here in my arms
                              Enjoy the silence
                              They can only do harm...
                              Eric Boer
                              Dev
