DR problems
  • DR problems
    Hi
    I have a problem with DR when using relative path, does not render the maps and when change to absolute path, everything works perfectly.
    Only I have a client which is the same situation, but it is irrelevant if this path with absolute or relative path.
    He has a mapped drive, with full control for all users, firewall turned off, or is this all correct, but it sometimes work and other conditions is not the maps.
    Someone can help-me?
    You could try using UNC path names instead of mapped drives.
      my dr will only work if the maps etc are located on the slave...I still don't know why, but I'm not messing with it anymore since it finally works. Good luck with it.
