sp3 fastsss2 and motion blur--flickerfest?
  • sp3 fastsss2 and motion blur--flickerfest?
    i've been doing some tests with the vrayfastsss2 material and a slow, short animated camera..
    i'm using a saved irradiance map that was generated using:
    - single frame
    - use camera path
    - light cache single frame
    - light cache use camera path
    my animation is rendered using the saved vrmap with LC turned off (secondary set to none). when motion blur is disabled, there is little to no flicker in the SSS material (prepass is still at -1, so i imagine setting this higher will reduce\eliminate it).
    however, when motion blur in the physical camera is enabled, the SSS material becomes very splotchy and flickery (relatively large scale flicker--looks like the paparazzi are flashing photography all over the place). is this a bug or a limitation? seems odd that motion blur would have this effect, since the motion blur itself is very subtle.
    vlado?
    thanks,
    greg
    It is a bug. It is fixed in the up-coming SP3a, but if you need the fix, please email me to vlado@chaosgroup.com
    [Edit] The bug is specifically with the "Use camera path" option and motion blur.
      Is this going to be about soon?
      We're doing sp3 in a week or two, will hold off if theres a bugfix.
        Yep, I hope to get it released this week, along with the 3ds Max 2010 version.
