Camera Map Per Pixel + Vertical shift
  • Camera Map Per Pixel + Vertical shift
    Hello,
    I am using a Camera Map Per Pixel using a Vray Camera with a vertical shift different from 0.0 . If i render the view, the Camera Map is not working properly and appears shifted vertically.
    Is there a way to correct this without using a Camera Map modifier on the geometry ?
    Thanks,
    0livier
    Does it work if you use max cam aligned to the vraycam for the mapping?
    Eric Boer
    Dev
      Hello,
      That means that i have also to match the FOV of the max cam and the focal of the vraycam... I will give a try. Thanks,
      0livier
        your trying to do 2.5mattepainting?
          Yes Da_elf, we can call it like this.
          The Camera Map Per Pixel works fine with no vertical correction on the vray camera..
          I need to match exactly the rendering output to the view... a 2.5 mattepainting as you name it.
          I still need to try the idea of Rerender..
          Cheers,
          0livier
            why use vray camera though. a max camera would work just as well
              I think one of the tools in Lele's script would match a VRAY cam to a Max cam as well
              Two heads are better than one ...
              ....but some head is better than none.....
                Thanks for all your answers, i will check all this.
                0livier
