Surface noise problem
  • Surface noise problem
    Hi all
    Got this noise problem on a project that I haven't had in many years. It's sort of surface/shadow noise that is some what different then the ordinary irradience splotches. I can compensate for the problem by cranking up the subdivs a lot more than usual, with very long rendertimes as a result. Any ideas on other settings to tweak?
    (Vray 1.5 SP2 on Max 2009. Scene in cm 1:1)
    Thanks from Chris
    It is probably from the VRayLights; try increasing the subdivs value for them.
      Increasing the light subdivs to about 50-60 gives the same amount of noise that I normally get in a scene with 16-20 subdivs on the lights :P something strange is going on here!
      Chris
        Bigger lights than usual ? or closer than usual ?
        A stripped down scene with only the lights and boxes would help..
        Regads,
        Thorsten
          You have glossy surfaces - use adaptive dmc and increase glossy subdivs on 'em. Also you may try to rise the AA to smth like 1/8 + increase subdivs to smth like 35 (materials and lights).
          I just can't seem to trust myself
          So what chance does that leave, for anyone else?
          CG Artist
            Can you show your vray settings ..
            Natty
            http://www.rendertime.co.uk
