Render nodes not rendering interpolation?
  • Render nodes not rendering interpolation?
    Vlado,
    odd problem today, yesterday all was fine!...
    all our render nodes will not render interpolation correctly, looks like missing imformation in the LC ? when we turn Interpolation off all is fine? the network is working fine and all drives can be seen, so im kinda stumpt here as we cant use interpolation all of a sudden? any thoughts?
    Nothing has changed in these two images apart from taking off interpolation.
    INTERPOLATION ON ...
    INTERPOLATION OFF ...
    N
    Natty
    http://www.rendertime.co.uk
    Another render brightened so you can see the errors more ...
    When Rendered on a single machine all is fine..
    Natty
      Which V-Ray version is this?
        The lastest Vlado
        .. but we noticed this in max 9 once, but it vanished from one render to another so i didnt report it but this time it wont go away, we have rebooted the whole system including the server but still the same.. do you want the file?
        Natty
          I have had intermittent problems with the same thing too. I never did pin down the source, mostly I just don't use interpolation and DR together anymore.
          b
          Brett Simms
          www.heavyartillery.com
          e: brett@heavyartillery.com
            Originally posted by natty View Post
            The lastest Vlado
            Yes, thanks for the scene. I will see if I can reproduce this here.
              Any luck Vladimir ? did you reproduce the error ?
              Natty
                Yes, thanks for the scene. It is fixed now if anyone needs this email me to vlado@chaosgroup.com
                  Thanks Vlado,
                  I know you worked hard yesterday to fix this problem, so thank you..
                  Natty
