Reflection or refraction problem
  • Reflection or refraction problem
    The facade of building I am rendering is made of many horizontal glass cilinder diameter 10cm.
    When I get close to building I have strange reflection or maybe refraction problem.
    It seams that I lose reflection at the distance.
    Any sugestions.
    www.VisualizationStudio.com
    What is the material on the walls?
    best regards,
      At a guess....what is your max refraction depth on the material?????
      If it is set to default of 5 then it probably isn't enough.....try raising it [sometimes I go as high as 20 if there are many overlapping glass objects.
      Hope it helps
        material...
          It seams the problem was in geometry because my cilinders have 6 sides and now I corected that to 18 and it looks ok.
