Poly
  • Poly
    Hi-
    I have this model that I got from Revit and it came in all meshed. When I apply a texture edge on the material it applies that edge to all the mesh lines. Is there anyway around this?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I don´t know if I really understand you the right way. As far as I remember, vray edges tex just render VISIBLE edges. Maybe you will try as follow:
    Convert the model to Editable Mesh (or add a Edit Mesh modifier). Go to sub-object mode and select edge. Then select all edges (CTRL-A). At the bottom of the Edit Mesh modyfier you can find the "Auto Edge" section. Enter a number like 2 or 5 and press "Auto Edge"-button. Try different numbers depending on you model. If the model is very big, try to find the right number with a selection instead of all the edges. Then deselect all edges and exit the subobject mode.
    Hope this can help you.
    Greets
    BLADE
