I have a character rigged with CAT, skinned and animated. after a while I got an unhandled exception error in vray with the turbosmooth on. I replaced the turbosmooth with a meshsmooth and It rendered ok.
I then rebooted the machine and put turbosmooth back and it rendered ok.
But as soon as I ticked "distributed rendering" I got some wierd effects.
If I turned this off the wierd effects went away.
I found that some of the remotely rendered buckets, the geometry was all over the place.
Also when I tried to render the scene with a number of xrefs in distributed render, I would only get the top left hand corner of the scene rendered (say 20 pixel square) and the rest of the frame buffer black would be unrendered or sometimes I would get a strange camera angle for my render frame. The strange camera angle would usually only occur with a camera attached to a path.
I moved turned the xrefs off and I no longer got the strange camera angle, but I did get the left hand corner effect.
so I cannot use my renderfarm (xpt perhaps with backburner) to render my scene
I have max 2010, vray 1.5sp3a both 32 and 64 bit windows xp
workstation computer = 64bit i7-940, one renderslave 64bit, 2 slaves 32bit. I tried individually taking the 64 bit or the 32 bit ones out of the farm but the problem still occurred.
Raj
Raj
