MultiMatteElement - not saving
  • MultiMatteElement - not saving
    Enable or Not Enabled - - no file is saved.
    Solution ?
    Nir
    3ds Max 2016/2021 (Vray 6.x), Windows 10 64bit , AMD 2990WX ThreadRipper 32/64 Cores, 128 gigs RAM , 2X RTX3090 48GB RAM
    are you splitting the render channels in the vray frame buffer? or are you saving to an EXR?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      Vray Frame buffer
      I dont work with EXR as I only output it to Photoshop
      Nir
        unless you save to a format which supports multiple channels, elements won't be saved in a single file. as jack suggests you can split them, and have each channel as an independent file.
          in the Vray frame buffer options in the render setup there is an option to "split render channels"
          Are you using this option?
          Chris Jackson
          Shiftmedia
            Will check this option- I never knew it existed.(usually not using VFB)
