Hair and Fur - not rendering with mr prim
  • Hair and Fur - not rendering with mr prim
    I'm just doing some simple preliminary grass tests with the Hair and Fur mod in Max 2010 and Vray sp3a.
    I have tried using MR Prim and no hair shows up. If I turn on Buffer or Geometry I see the hair.
    What am I missing?
    Also, what is the difference between MR Prim and Geometry modes? (assuming I can get MR Prim working)
    Does it work on a simple scene?
    The difference is that the fur is rendered similar to VRayFur - as dynamic geometry, which saves quite a lot of memory.
      Yeah, it was a real simple scene... but nevermind -- because this morning it works. I"m starting to think something is a little wacky with Max. I had a similar issue a few weeks ago where RT wasn't updating when I changed materials. And the next day it was working fine.
      For some reason I'm getting these little failures at sporadic times. I do know someone else said they say this issue in RT -- so I'm not entirely alone.
      Anyway, I really like that you added this memory saving option, Vlado.
