Alert!
  • Alert!
    Does anybody know why I get this Alert? The file does not exist.
    0: [2009/Jul/21|17:17:34] ========================== Starting new session ==========================
    1: [2009/Jul/21|17:17:34] Got this module name: C:\Program Files\Autodesk\3ds Max Design 2010\vrayspawner2010.exe
    2: [2009/Jul/21|17:17:34] Got this INI file name: C:\Program Files\Autodesk\3ds Max Design 2010\VRaySpawner.ini
    3: [2009/Jul/21|17:17:34] *** ALERT! Could not open INI file: "C:\Program Files\Autodesk\3ds Max Design 2010\VRaySpawner.ini". Using defaults.
    4: [2009/Jul/21|17:17:34] --
    5: [2009/Jul/21|17:17:34] Dumping current settings...
    6: [2009/Jul/21|17:17:34] VRaySpawner temp dir: "C:\Program Files\Autodesk\3ds Max Design 2010\network"
    7: [2009/Jul/21|17:17:34] Application name (MAX/VIZ): "C:\Program Files\Autodesk\3ds Max Design 2010\3dsmax.exe"
    8: [2009/Jul/21|17:17:34] --
    9: [2009/Jul/21|17:17:34] Process id is 2604 (0xa2c)
    10: [2009/Jul/21|17:17:34] Executing ""C:\Program Files\Autodesk\3ds Max Design 2010\3dsmax.exe" -server C:\Program Files\Autodesk\3ds Max Design 2010\network\vraydummy2010.max"
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Because the file specified is not there. This is ok - the file was used before to specify 3dsviz.exe as the application if you had AutodeskVIZ installed, but this is no longer used.
