Hi, long time lurker, first time poster.
Am having a situation where if Irradiance Map and Photon Map are calculated and then image is rendered, render time is x. If those saved Irradiance and Photon Maps are then used to render with the "from file" option, the render time increases to almost x times 2. So many questions, so little time before work has to go to the renderfarm...any thoughts on this please drop a couple lines.
Thing is I remember testing stuff like this and the times for each render, either continuous after calc, or from file option, were the same.
btw it is actually more then x times 2 if in a LWF method.
Thanks for reading.
Thanks for reading.
