Vray Config File...is any such thing?
  • #16
    Trying to get a DR job running through backburner using Vray 1.50.SP5
    Could you please clarify how this should be done?
    So far, I have copied the file 'vary_dr.cfg' from C:\Documents and Settings\my.name\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\plugcfg to one of our render slaves, NODE_01 to C:\Documents and Settings\administrator.DOMAIN\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\plugcfg.
    The file looks like this:-
    Code:
    node_01 1
    node_02 1
    node_03 1
    node_04 1
    node_05 1
    node_06 1
    node_07 1
    node_08 1
    restart_slaves 1
    list_in_scene 0
    Is this correct?
    I then send the DR job to NODE_01 through backburner.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    • #17
      Yep, that should work if you run the backburner server with the administrator.DOMAIN user.
