DR
  • DR
    Would a plug-in keep DR from starting? I istalled Forest Lite on my workstation and slaves. v-ray is saying the the scene loaded and started, but it isn't using any cores. I am 4 hours into the scene with 10 hrs to go and the only buckets showing are the master workstation.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Look at the log file on the render slaves to see what they are doing, it may give you some hints.
      DR
      Nothing out of the ordinary.
      [2009/Aug/12|16:58:54] ================================================== ==========
      [2009/Aug/12|16:58:54] Console created, V-Ray Adv 1.50.SP3a for x64 from Apr 8 2009, 16:28:32
      [2009/Aug/12|16:58:54] Compiled with Intel C++ compiler, version 11
      [2009/Aug/12|16:58:54] Host is 3dsmax, version 12
      [2009/Aug/12|16:58:54] V-Ray DLL version is 1.70.00
      [2009/Aug/12|16:59:14] Starting DR session from 192.168.8.189
      [2009/Aug/12|16:59:14] Receiving DR scene from 192.168.8.189
      [2009/Aug/12|16:59:57] [VRender] Constructor entered (loading from file).
      [2009/Aug/12|16:59:57] Setting default filter kernel.
      [2009/Aug/12|16:59:57] [VRender] Constructor done.
      [2009/Aug/12|16:59:57] Loading from file.
      [2009/Aug/12|16:59:57] Loading filter parameters.
      [2009/Aug/12|16:59:57] Loading done.
      [2009/Aug/12|16:59:59] Scene loaded from "C:\Documents and Settings\Default User\Local Settings\Application Data\Autodesk\3dsMaxDesign\2010 - 64bit\enu\temp\vray_server_scene.max"
      [2009/Aug/12|17:00:00] Extracting sequence data from RendParams.
      [2009/Aug/12|17:00:00] Setting up V-Ray parameters for frame rendering.
      [2009/Aug/12|17:00:00] Extracting sequence data from VRender.
      [2009/Aug/12|17:00:00] Forcing multithreading
      [2009/Aug/12|17:00:00] A render elements manager with 1 elements detected
      [2009/Aug/12|17:00:00] Render element: VRayZDepth
      [2009/Aug/12|17:00:00] Current project folder is "C:\Users\vlado\Documents\3dsMax"
      [2009/Aug/12|17:00:00] Entering beginSequence().
      [2009/Aug/12|17:00:00] Setting RenderGlobalContext.
      [2009/Aug/12|17:00:00] Broadcasting NOTIFY_PRE_RENDER.
      [2009/Aug/12|17:00:00] Preparing renderer...
      [2009/Aug/12|17:00:00] Creating render callback from built-in VFB.
      [2009/Aug/12|17:00:00] warning: Subpixel color mapping is on: rendered result may have incorrect brightness.
      [2009/Aug/12|17:00:00] Calling renderBegin().
      [2009/Aug/12|17:00:00] Sending RenderBegin().
      [2009/Aug/12|17:00:00] Sending RenderBegin() to atmospheric effects.
      [2009/Aug/12|17:00:00] Sending RenderBegin() to render effects.
      [2009/Aug/12|17:00:00] Sending RenderBegin() to environment maps.
      [2009/Aug/12|17:00:00] Sending RenderBegin() to the tone operator.
      [2009/Aug/12|17:00:00] Sending RenderBegin() to override mtl.
      [2009/Aug/12|17:00:00] Adding global illumination light
      [2009/Aug/12|17:00:00] Created global illumination light.
      [2009/Aug/12|17:00:00] Light added to light list.
      [2009/Aug/12|17:00:00] Scanning scene.
      [2009/Aug/12|17:00:00] Created light from node.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        DR and plug-ins
        I had my Forest Lite installed wrong so the answer is yes, a plug-in can keep DR from working correctly .
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
